RedMoose's avatar
RedMoose
Using a RT-AC68U Asus as an access point for an Orbi (RBK50)set-up?
First - I am not super techno saavy. I just want to make sure I have good coverage in a 4000sf 2 story house. I just got the RBK50. I am going to put one up stairs (all bedrooms are upstairs), and one unit downstairs. I am replacing an Asus RT-AC68U, but is that compatible to use as an additional access point in the garage area? Any help is appreciated.
  • Is the garage attached to the house or separate?
    The orbi you have should cover the house and then some including the garage if it's attached.
    The distance between the router and satellite(s) is 30 feet is recommended in between them to begin with depending upon building materials.
    I have a 5000sq ft home with just the base router and 1 satellite at the opposite end from the router. 40 feet in between. Great coverage including in my garage.
    Having additional Wireless APs can cause problems. I would go with what you have with the Orbi if possible. Placement is key.
    • RedMoose's avatar
      RedMoose
      Garage is attached. If you are covering that much area with the same setup, then I think you are right - less hardware = less problems. Thank you!
  • I recommend continuting to use the Asus as your router. Put the Orbi router into AP mode and turn off the Asus's WiFi radios. Then the Orbis will talk WiFi to each other better than the Asus would, and the Asus will route better than the Orbi would.
    This is my setup. AC68U as router and 3 Orbis for WiFi.
    • CrimpOn's avatar
      CrimpOn
      Guru
      I did a similar thing.  Some of my security cameras were not happy because of where I put the router and satellite.  So, I put my old Nighthawk R7000 in the garage as an access point, connected to the Orbi over Powerline adapters.  The cameras are now happy.  Of course, I set up a different SSID just for these devices.  i.e. my Orbi WiFi has all the Orbi features and the R7000 access point does not - but I don't care.  I don't use WiFi outside of that corner of the house.  If I had it to do all over again, I probably wouldn't have purchased 5G wireless security cameras and wouldn't have needed WiFi in that location.  (Could have used PoE cameras with a switch and Powerline.  But all that stuff happened after the cameras went up.)  Or, maybe I could have tried moving the satellite around.  Once "things worked", I quit fussing with it and moved on to other projects.
