Sner
Jul 29, 2018Aspirant
Using AC300 router/satellite as access point
I purchased the 3000 (router + 1 satellite) yesterday and it works fine in 6000 sq ft home.. I have it set up as an access point since I want my existing roiuter to handle IP assignment. Two questi...
- Jul 30, 2018
Yes, if the in wall LAN cabling is good and it connects to a good working patch panel and it' to a NON managed switch, you can connect the satellites wired back haul for best performance:
Jul 30, 2018Guru - Experienced User
