rrreinig
Sep 22, 2021Tutor
Using Airplay with Orbi mesh
I have an Orbi RBR50 mesh system with one router and two satellites. Everything works correctly except airplay. It fails when trying to connect from my iphone to Apple TV or iphone to my LG smart TV....
rrreinig
Sep 22, 2021Tutor
Here are a few other bits of information:
I have updated the firmware on all orbi routers and satellites.
I have updated firmware on my iphone.
I have power cycled the entire system after all updates.
The problem hasen't changed.
rrreinig
Sep 24, 2021Tutor
More information:
I tried disconnecting the hardwired ethernet connection to each of my Apple TVs and running them on the wifi (the same wifi my iphone is connected to).
The problem persists unchanged. So this is not a hardwire problem as I suspected earlier.
I tried using two different iphones. No change to the problem.
This may be an issue for Apple to solve.
