bmeighan's avatar
Apr 06, 2020
Using an Apple router on Orbi
I have read here that you can repurpose an Apple Airport device (like an Airport Extreme) as an extender on the Orbi mesh network provided that you enable Bridge mode on the Airport device and connect the Airport using Ethernet to the Orbi. I also confirmed that it works. The problem I have is that although I can use the Orbi's main network SSID (for example, Smith) while on the Extreme, I cannot get it to recognize the guest network of the Orbi mesh. In other words, the network name (SSID of Smith) and the guest network name (SSID: Smith Guest) are both set up identicallyt on the Orbi and the Airport Extreme. When I'm in range of the Airport Extreme I can use the Smith network but cannot get the Orbi's guest network. Any ideas how I can use the Airport Extreme as an extender for the guest network too?
    • bmeighan's avatar
      bmeighan
      Tutor
      Thanks to your hugely helpful responses and ideas, I may now go with a simpler solution to solve the issue with extending the guest network on an Airport Extreme connected to an Orbi router. Here is my proposed solution and a question before I do it.
      Since the "remote" location (a detached guest home where I have ethernet connecting the networks) requires only guest network privileges, I'm thinking of swapping the network names (SSID) on the Orbi router. In other words, I plan to use SSID "Smith Guest" (Smith is used as the example network name) as the main network and SSID "Smith" as the guest network. Since I only need the Smith Guest network in my guest home and the only extender device is the Extreme in that location, it leaves my main home with both networks and still allows me to use both networks on my Orbi router and Orbi satellites. I believe this will solve my problem. By the way, my router and all satellites (including the Extreme) are connected by ethernet cable.
                           |----> Extreme ----> Smith Guest House ---> Smith Guest network
        Orbi Router |---------------------> Smith Main House ----> Smith Guest & Smith networks
                           |----> Orbi Sat1 ---> Smith Main House ----> Smith Guest & Smith networks
                           |----> Orbi Sat2 ---> Smith Main House ----> Smith Guest & Smith networks
      My question is this: Are the main and guest networks on an Orbi mesh network prioritized similarly? In other words, I do not want the guest network (now named Smith and used for 90% of the network traffic) to be compromised or slowed by swapping network names. Thanks again for your help.
      • ekhalil's avatar
        ekhalil
        Master
        You don’t need to swap the SSID’s in the Orbi network. My suggestion is as follows;
        - Keep Smith as main network and Smith Guest as guest network in Orbi.
        - Set the SSID for the main network in the AE as Smith Guest and disable the guest network in the AE.
  • FURRYe38's avatar
    I don't think you can bridge two SSID connections when using the wireless bridge mode. You can only use one at a time. At least thats what I found with my 3rd gen AE. Maybe follow on gens can. Ask Apple about this.
    • bmeighan's avatar
      bmeighan
      Tutor
      Super thanks! I will give that a try. It's a very simply, yet elegant solution.
