baker_pharmd
Sep 06, 2019Aspirant
Using an Orbi with Nighthawk R7500
I have DSL internet fed to my home via fiber optics. I have the wall connection feeding into my Nighthawk R7500 and the Orbi connected to the Nighthawk via ethernet. I am not getting the speeds tha...
- Sep 06, 2019
You should ether configure the Orbi RBR for AP mode if you use the R7500 has your main host router or completely remove the R7500 from the mix and configure the RBR for router mode.
Sep 06, 2019Guru - Experienced User
- baker_pharmdSep 06, 2019AspirantWould I need to get a modem then? Before the Orbi, the nighthawk worked great plugged into the wall. I got the Orbi because I wanted to eliminate the dead zones in my home.
- FURRYe38Sep 06, 2019Guru - Experienced User
The Orbi will replace what the R7500 is doing. Won't need a modem....
- baker_pharmdSep 06, 2019AspirantThanks for the info. I’ll try tonight and update you. Much appreciated!
