baker_pharmd's avatar
baker_pharmd
Using an Orbi with Nighthawk R7500
I have DSL internet fed to my home via fiber optics.  I have the wall connection feeding into my Nighthawk R7500 and the Orbi connected to the Nighthawk via ethernet.  I am not getting the speeds tha...
  • FURRYe38's avatar
    Sep 06, 2019
    You should ether configure the Orbi RBR for AP mode if you use the R7500 has your main host router or completely remove the R7500 from the mix and configure the RBR for router mode.
