gelliott1
Oct 27, 2019Aspirant
using apple Remote Desktop with orbi and satellites
hi thre, can anybody tell me how I enable apple remote desktop on an orbi ? I see in my remote desktop window (apple software) that for screen sharing port 5900 is greyed out, and remote management 3...
gelliott1
what does this mean from the link you sent please?
Specify the desired external port number
("External port range"),
gelliott1
also do i need to fix the IP address of the target system? I reserved it but still shows as the old one in the attached devices list
- ekhalilOct 27, 2019Master
gelliott1 wrote:also do i need to fix the IP address of the target system? I reserved it but still shows as the old one in the attached devices list
Yes, you need to use a static IP address or a reserved DHCP IP address for the target computer.
How did you reserve the IP address? After you reserve an IP address in Orbi you need to force the computer to renew it's IP address (e.g by rebooting it).
- gelliott1Oct 27, 2019Aspirant
will do that now
