pup0975
Sep 17, 2017Star
Using devices that require 2.4ghz on Orbi
I'm considering buying a device (AmbientWeather Weather Station) that says that it only works on the 2.4ghz wifi and if you have a dual band router, you need to turn off the 5ghz radio. I already hav...
Smitty_P
Sep 18, 2017Aspirant
I have a Ambiant WS-0262 and it does not work with my Orbi. Cant figure how to shut off 5 ghz. The AmbiantTool does not see the WS.
- pup0975Sep 18, 2017Star
Smitty_P, Go to Advanced tab then Advanced Set up then Wireless setting. I think if you uncheck "Enable SSDI Broadcast" on the 5ghz setting, it turns off the ability of the Ambient to connect to the 5ghz. Is that waht you've done, Tim-in-CA? The other thing I thought was taking the device as far away from the Orbi to "force" it to connect to the 2.4ghz network since 2.4 ghz travels further than the 5ghz. Let me know if this works.
- Tim-in-CASep 18, 2017Star
pup0975 wrote:Smitty_P, Go to Advanced tab then Advanced Set up then Wireless setting. I think if you uncheck "Enable SSDI Broadcast" on the 5ghz setting, it turns off the ability of the Ambient to connect to the 5ghz. Is that waht you've done, Tim-in-CA? The other thing I thought was taking the device as far away from the Orbi to "force" it to connect to the 2.4ghz network since 2.4 ghz travels further than the 5ghz. Let me know if this works.
Yup. That's what I did to get my Rachio to connect. After the Rachio was configured, I reenabled 5GHz SSID broadcast and the Rachio has remained connected.
- Nina027Jul 04, 2018AspirantWhere and how do you go to advance settings?
- rpgraveyDec 23, 2017Aspirant
Even after turning off 5ghz SSID broadcast, my iphone still shows as connected to 5ghz. I have "forgot the network" and logged back in, to no avail. I'm trying to connect the Ambient Weather station but it needs to have the phone on 2.4ghz.
- pup0975Dec 24, 2017StarI’m a bit confused. Why does the phone need to be on 2.4ghz? Just the Ambient Station needs to be on 2.4ghz. Once the Ambient Station connects, just turn the 5ghz back on. One issue I did discover is that if the Ambient is connected to a satellite but the phone is connected to the main router (or vice versa), it won’t see the Ambient for the set up process. Some reason that causes the Ambient to be on a “different” network. That may be the issue you’re having.
- jescott3Jan 31, 2018Guide
I have an Ambient Weather Osprey WS-2902 system, an Orbi Router with 2 satellites, and an Apple iPad Mini and iPhone 5S. When the turn-off-5 GHz-SSID-broadcast trick didn't work, I then turned the 5 GHz power down to 25% and voila!, the WS-2902 connected immediately to the Internet. The amazing thing was, everything was within 6 feet of the Orbi router in my office when it happened.
