pup0975
Sep 17, 2017Star
Using devices that require 2.4ghz on Orbi
I'm considering buying a device (AmbientWeather Weather Station) that says that it only works on the 2.4ghz wifi and if you have a dual band router, you need to turn off the 5ghz radio. I already hav...
Smitty_P
Sep 18, 2017Aspirant
I have a Ambiant WS-0262 and it does not work with my Orbi. Cant figure how to shut off 5 ghz. The AmbiantTool does not see the WS.
pup0975
Sep 18, 2017Star
Smitty_P, Go to Advanced tab then Advanced Set up then Wireless setting. I think if you uncheck "Enable SSDI Broadcast" on the 5ghz setting, it turns off the ability of the Ambient to connect to the 5ghz. Is that waht you've done, Tim-in-CA? The other thing I thought was taking the device as far away from the Orbi to "force" it to connect to the 2.4ghz network since 2.4 ghz travels further than the 5ghz. Let me know if this works.
- Tim-in-CASep 18, 2017Star
pup0975 wrote:Smitty_P, Go to Advanced tab then Advanced Set up then Wireless setting. I think if you uncheck "Enable SSDI Broadcast" on the 5ghz setting, it turns off the ability of the Ambient to connect to the 5ghz. Is that waht you've done, Tim-in-CA? The other thing I thought was taking the device as far away from the Orbi to "force" it to connect to the 2.4ghz network since 2.4 ghz travels further than the 5ghz. Let me know if this works.
Yup. That's what I did to get my Rachio to connect. After the Rachio was configured, I reenabled 5GHz SSID broadcast and the Rachio has remained connected.
