pup0975
Sep 17, 2017Star
Using devices that require 2.4ghz on Orbi
I'm considering buying a device (AmbientWeather Weather Station) that says that it only works on the 2.4ghz wifi and if you have a dual band router, you need to turn off the 5ghz radio. I already hav...
rpgravey
Dec 23, 2017Aspirant
Even after turning off 5ghz SSID broadcast, my iphone still shows as connected to 5ghz. I have "forgot the network" and logged back in, to no avail. I'm trying to connect the Ambient Weather station but it needs to have the phone on 2.4ghz.
pup0975
Dec 24, 2017Star
I’m a bit confused. Why does the phone need to be on 2.4ghz? Just the Ambient Station needs to be on 2.4ghz. Once the Ambient Station connects, just turn the 5ghz back on. One issue I did discover is that if the Ambient is connected to a satellite but the phone is connected to the main router (or vice versa), it won’t see the Ambient for the set up process. Some reason that causes the Ambient to be on a “different” network. That may be the issue you’re having.
- jescott3Jan 31, 2018Guide
I have an Ambient Weather Osprey WS-2902 system, an Orbi Router with 2 satellites, and an Apple iPad Mini and iPhone 5S. When the turn-off-5 GHz-SSID-broadcast trick didn't work, I then turned the 5 GHz power down to 25% and voila!, the WS-2902 connected immediately to the Internet. The amazing thing was, everything was within 6 feet of the Orbi router in my office when it happened.
- ncrichDec 30, 2018Aspirant
I installed an Orbi to replace my daughter's netgear router (6320 I think). Her other devices like sonos, nest camera, etc worked fine but could not connect filimin lamp since it will only work on 2.4 GHz and cannot connect to 5 GHz Orbi due to sharing same SSID between both bands. After reading this post we reduced the 5 GHz transmit power level to 25% and the filimin connected with no problems. Thanks for the suggestion. It's good to be back in her good graces again.:smileyvery-happy:- FURRYe38Dec 30, 2018Guru - Experienced User
Glad it worked and things are working again.
Enjoy. :smileywink:
