pup0975
Sep 17, 2017Star
Using devices that require 2.4ghz on Orbi
I'm considering buying a device (AmbientWeather Weather Station) that says that it only works on the 2.4ghz wifi and if you have a dual band router, you need to turn off the 5ghz radio. I already hav...
Devora
May 24, 2018Aspirant
Hi you stated you set up a Skybell to an orbi. During your setup did you have to isolate the 2.4ghz channel on the orbi or did you just go straight into the Skybell app and set the doorbell up without having to do anything to Orbi?
pup0975
May 24, 2018Star
I don't think I had to separate it out when connecting, but my Skybell is probably far enough away from the main router to connect to the 2.4 signal. You can try connecting without doing anything first. If it fails, then isolate the 2.4 signal, connect to the wifi, then can turn the 5 back on.
