pup0975
Sep 17, 2017Star
Using devices that require 2.4ghz on Orbi
I'm considering buying a device (AmbientWeather Weather Station) that says that it only works on the 2.4ghz wifi and if you have a dual band router, you need to turn off the 5ghz radio. I already hav...
jescott3
Feb 01, 2018Guide
I have an Ambient Weather Osprey WS-2902 system, an Orbi Router with 2 satellites, and an Apple iPad Mini and iPhone 5S. When the turn-off-5 GHz-SSID-broadcast trick didn't work, I then turned the 5 GHz power down to 25% and voila!, the WS-2902 connected immediately to the Internet. The amazing thing was, everything was within 6 feet of the Orbi router in my office when it happened.
ncrich
Dec 30, 2018Aspirant
I installed an Orbi to replace my daughter's netgear router (6320 I think). Her other devices like sonos, nest camera, etc worked fine but could not connect filimin lamp since it will only work on 2.4 GHz and cannot connect to 5 GHz Orbi due to sharing same SSID between both bands. After reading this post we reduced the 5 GHz transmit power level to 25% and the filimin connected with no problems. Thanks for the suggestion. It's good to be back in her good graces again.:smileyvery-happy:
- FURRYe38Dec 31, 2018Guru - Experienced User
Glad it worked and things are working again.
Enjoy. :smileywink:
ncrich wrote:
I installed an Orbi to replace my daughter's netgear router (6320 I think). Her other devices like sonos, nest camera, etc worked fine but could not connect filimin lamp since it will only work on 2.4 GHz and cannot connect to 5 GHz Orbi due to sharing same SSID between both bands. After reading this post we reduced the 5 GHz transmit power level to 25% and the filimin connected with no problems. Thanks for the suggestion. It's good to be back in her good graces again.:smileyvery-happy: - schumakuDec 31, 2018Guru - Experienced User
ncrich wrote:
I installed an Orbi to replace my daughter's netgear router (6320 I think). Her other devices like sonos, nest camera, etc worked fine but could not connect filimin lamp since it will only work on 2.4 GHz and cannot connect to 5 GHz Orbi ...A 2.4 GHz only device does not care about the 5 GHz network, regardless if it's the same or a different SSID.
The previous poster Ambient Weather WS-2902A Smart WiFi Weather Station as well as the Filimin lights work on 2.4 GHz only. These devices have no problems if there are 5 GHz, 60 GHz, Bluetooth, Z-Wave, or whatever in the air.ncrich wrote:
...due to sharing same SSID between both bands. After reading this post we reduced the 5 GHz transmit power level to 25% and the filimin connected with no problems.Again, no!
Some smart-a** IoT installation programs do ugly things - that's the problem. If whatever installer App does check if the mobile is connected to a 5 GHz or a 2.4 GHz and does error-out if the client is associated to a 5 GHz network it's not a router problem: Not a problem if the same SSID on all radios. Not an Orbi problem. Not any other WiFi router problem. Not any wireless access point. Not even the IoT device problem - which can perfectly communicate with the Orbi 2.4 GHz once configured, even if it is implemented in an earlier 802.11 standard.There is absolutely nothing wrong with using the same SSID to connect to the same network. Regardless how many wireless access points and radios are in the game - it is the same L2 network.- jbahlmanDec 31, 2018Aspirant
The issue is the device you are connecting to the weather station with needs to be connected to the wifi via 2.4ghz or it can't give the settings to the weather station. If you turn off the 5ghz or just connect to the 2.4ghz then it will work.
The weather station does give a s**t about the AP 5 GHz - it does operate on 2.4 GHz ONLY. As such it can only work with the 2.4 GHz radio. So why bother switching off 5 GHz please? The answer is because some ***** discovery Apps. Not because of the same SSID on all Orbi radios. Complain to the markers of these toys.
