pup0975
Sep 17, 2017Star
Using devices that require 2.4ghz on Orbi
I'm considering buying a device (AmbientWeather Weather Station) that says that it only works on the 2.4ghz wifi and if you have a dual band router, you need to turn off the 5ghz radio. I already hav...
ncrich
Dec 30, 2018Aspirant
jescott3 wrote:
I have an Ambient Weather Osprey WS-2902 system, an Orbi Router with 2 satellites, and an Apple iPad Mini and iPhone 5S. When the turn-off-5 GHz-SSID-broadcast trick didn't work, I then turned the 5 GHz power down to 25% and voila!, the WS-2902 connected immediately to the Internet. The amazing thing was, everything was within 6 feet of the Orbi router in my office when it happened.
I installed an Orbi to replace my daughter's netgear router (6320 I think). Her other devices like sonos, nest camera, etc worked fine but could not connect filimin lamp since it will only work on 2.4 GHz and cannot connect to 5 GHz Orbi due to sharing same SSID between both bands. After reading this post we reduced the 5 GHz transmit power level to 25% and the filimin connected with no problems. Thanks for the suggestion. It's good to be back in her good graces again.:smileyvery-happy:
Dec 30, 2018Guru - Experienced User
Glad it worked and things are working again.
Enjoy. :smileywink:
