pup0975
Sep 17, 2017Star
Using devices that require 2.4ghz on Orbi
I'm considering buying a device (AmbientWeather Weather Station) that says that it only works on the 2.4ghz wifi and if you have a dual band router, you need to turn off the 5ghz radio. I already hav...
jbahlman
Dec 31, 2018Aspirant
The issue is the device you are connecting to the weather station with needs to be connected to the wifi via 2.4ghz or it can't give the settings to the weather station. If you turn off the 5ghz or just connect to the 2.4ghz then it will work.
schumaku
Dec 31, 2018Guru - Experienced User
The weather station does give a s**t about the AP 5 GHz - it does operate on 2.4 GHz ONLY. As such it can only work with the 2.4 GHz radio. So why bother switching off 5 GHz please? The answer is because some ***** discovery Apps. Not because of the same SSID on all Orbi radios. Complain to the markers of these toys.
- michaelkenwardJan 01, 2019Guru - Experienced User
schumaku wrote:
The answer is because some ***** discovery Apps. Not because of the same SSID on all Orbi radios. Complain to the markers of these toys.Dead right there.
It seems that too many of these devices come with installation and control apps that can't get their act together when faced with 2.4 GHz and 5 GHz wifi.
The hardware works at 2.4 GHz and is blissfully ignorant about even the possibility of 5 GHz. Unfortunately, the installation apps are on devices that do know about 5 GHz. The apps should still be able to get the hardware to connect even when they are on a 5 GHz connection, but that seems to be beyond the wit of the app writers.
Turning off the 5 GHz has nothing to do with communication between trhe hardware and the wifi. It is all about the connection between the setup app and the wifi.
The bit of problem that is unique to Orbi is that it is not as easy to disable 5 GHz as it is on other routers.
- FURRYe38Jan 01, 2019Guru - Experienced User
Also disabling the 5Ghz radio seems to be hiding the fact the this seems to place blame on the MESH router Mfr rather then having the device Mfr take resposibillity for there product and handling of it to ensure there product works on ALL wifi routers, regardless of MESH or NOT. Think router Mfr should push back on device Mfrs more and stop passing the buck. Stop blaming the router mfr for the device mfr bad development and handing of there products.
