AKLGUY's avatar
AKLGUY
Apprentice
Jun 14, 2018
Using DNS 1.1.1.1
Just wondering if anyone has tried to use 1.1.1.1 (&1.0.0.1) as their IPv4 DNS settings
Read more here: https://1.1.1.1
  • I am using it for both ip v4 and 6 on my rbk53 system. Works well, no complaints.
    • AKLGUY's avatar
      AKLGUY
      Apprentice
      Have you keyed the settings in your router/Orbi or just into your devices?
      • joknutsen's avatar
        joknutsen
        Guide
        Hi, I made the changes to the settings directly in the router. Updating each device manually would take to much time, break automation and make it more difficult to troubleshoot. The only exception I see is if you got a dedicated DHCP server and a more complex hardware set up.
  • FURRYe38's avatar
    Been using this and 9.9.9.9. Zero issues so far.
  • Using 1.1.1.1, Quad9 and Google for my IPv4 and Quad9 and Google for IPv6 on my system. I didn't check to see if they had setup IPv6 but since they are I will switch out Google for them.
  • Yeah, I use Cloudflare's and Google's DNS servers for DNS, set on the router. No issues.
  • FURRYe38's avatar
    I've been using cloudfare and quad 9 DNS. Zero issues.
