Jasonsch69
Feb 17, 2019Aspirant
Using Ethernet port on satellite disconnects it
I have been using the Ethernet port on one of the satellites to connect a U-verse wireless receiver via Ethernet for a few months with no issues. I went on vacation and came back the U-verse box was o...
randomousity
Feb 17, 2019Luminary
Something about the firmware seems to make it so the satellite won't sync with the router when it comes on if there are any devices connected with ethernet to the satellite. Basically, any time you power cycle the satellite, lose power, add a new satellite, etc., you'll have to disconnect anything from your satellite(s), wait for them to boot and sync, then connect the cables back. Once they'e booted and synced, you should be able to reconnect any wired devices with no problem.
Chuck_M
Feb 17, 2019Mentor
What is Daisy Chain option marked as? Try disabling that if checked.
- Jasonsch69Feb 18, 2019AspirantUnchecked daisy chain. Same issue.
- Chuck_MFeb 18, 2019Mentor
Are you using IPV6 there?
- Jasonsch69Feb 19, 2019AspirantNo
