Jasonsch69
Feb 17, 2019Aspirant
Using Ethernet port on satellite disconnects it
I have been using the Ethernet port on one of the satellites to connect a U-verse wireless receiver via Ethernet for a few months with no issues. I went on vacation and came back the U-verse box was o...
Jasonsch69
Feb 19, 2019Aspirant
I am running in AP mode. Backhaul signal is showing good for both satellites on 5ghz. All is running great until I try to connect the uverse box vis ethernet. Once I connect, the satellite led turns purple, then blue and then the internet goes offline on the router. If I disconnect the ethernet again and reboot the satellite all is good again. Using att bgw520 as router and DHCP provider connected to wan port on orbi router.
Jasonsch69
I'm going to factory reset all 3 orbi devices and start over.
