ripclaw
Jul 15, 2021Follower
Using EX6410 extender with existing Orbi RBR50 Mesh network
Hi
I have an existing Orbi Mesh network at home (RBR50) - router + single satellite.
Can i connect the EX6410 extender to this existing mesh network? I just need to extend the coverage slightly to cover a part of the house where the connection is weak.
The area is currently covered by the satellite but because its a little far, signal is weak. I cannot move the satellite any closer to cover the area or it will go out of range with the router (hope this makes sense)
Thanks
1 Reply
I've seen other use simple extenders and add to their Orbi network. It doesn't integrate with the system with the smart roaming/single ssid function and it doesn't use the wireless backhaul but it does work.
