Henrykoh
Aug 31, 2017Follower
Using genie to enable guest wifi
After i updated the netgear orbi to 1.12.0.18 , im not able to enable guest wifi using the genie app. It says router does not support guest wifi. Before i update to this latest firmware it's working w...
Bing-Stroller
Sep 01, 2017Luminary
My Genie app updated to a new version last night
Version 3.1.36 dated 29 Aug 2017
It might be worth checking if you are on the latest release.
- BillYoungSep 04, 2017Luminary
Bing-Stroller:
I am updated to the latest version of the Genie app on my cell phone: 3.1.36.
Every time I try to access the Guest WiFi, it tells me that "This router do not support guest WiFi."
Now if I use the Genie app on my PC, which is version 2.4.26, it accesses the Guest WiFi just fine.
So it sounds like to me there is a bug in the cell phone version of the Genie app.
BillYoung
- BmMdlkSep 15, 2017Tutor
Same exact thing for me.
- JMU1998Sep 15, 2017Luminary
Same issue here as well. Also another issue that has been around for many many months is if you click on the "Network Map" button in Genie all devices show 100% signal strength which is bogus! and link rate as N/A so is Engineering ever going to fix this or continue to ignore? they have acknowledge the issue many months ago.
