rsleonard
Aug 23, 2020Tutor
Using "locking" bracket for Orbi Outdoor Satellite -- HELP!!
I recently purchased an Orbi RBS50Y. We've had an Orbi Router plus two Orbi Satellites for about a year, and they have worked well. But whoever engineered the mounting system for the RBS50Y needs to ...
schumaku
Aug 23, 2020Guru - Experienced User
The lock can't slide over the mount so the screw holes allign (red lines)?
- rsleonardAug 23, 2020Tutor
SERIOUSLY? THAT IS THE SAME ILLUSTRATION THAT CAME IN THE BOX.
Thanks for your help. Not.
- schumakuAug 23, 2020Guru - Experienced User
rsleonard wrote:SERIOUSLY? THAT IS THE SAME ILLUSTRATION THAT CAME IN THE BOX.
- This is a customer community.
- I'm neither Netgear nor Netgear support.
- I have just asked a question to clarify.
- Shouting is so hmmmmm....
No, the one in the box does not have the red lines ...
- MstrbigAug 23, 2020Master
I find some users asking for help can get a little testy. They forget we are just trying to help them resolve THEIR problem. I myself appreciate any and all input, even if wrong, as it sometimes jars the brain into looking at the cable laying on the floor that should be plugged in. :smileywink::smileylol:
