rsleonard
Aug 23, 2020Tutor
Using "locking" bracket for Orbi Outdoor Satellite -- HELP!!
I recently purchased an Orbi RBS50Y. We've had an Orbi Router plus two Orbi Satellites for about a year, and they have worked well. But whoever engineered the mounting system for the RBS50Y needs to ...
rsleonard
Aug 23, 2020Tutor
I did exactly what you suggested. The screws in the locking bracket are approximately 1/4" above the location of holes in the wall mounted bracket, making ithe locking bracket entirely useless.
Your support department's answer...SEND BACK TO AMAZON. Instead of sending me brackets that work. What kind of support is that.
Mstrbig
Aug 23, 2020Master
Is, by any chance the bracket is warped because of where it was mounted? We had a problem mounting on a Spanish stucco wall. Ended up having to shim it to keep it straight.
