thepybus
Dec 20, 2018Aspirant
Using my rbr50 with Synology NAS
I am wanting to make my Synology NAS accessible over the internet and one of the requirements is that the router supports UPnP.
I have searched my Netgear Genie and cannot find any reference to UPn...
st_shaw
Dec 20, 2018Master
You do not need UPNP to access your Synology NAS from the Internet. You just need to forward the appropriate ports that are used by the services on your NAS that you wish to access. The DiskStation web interface (DSM) uses port 5001 for https access. The other ports are listed here:
ekhalil
Dec 22, 2018Master
UPnP is the “automatic” or “plug & play” way of doing port forwarding. So if both the device and the router support UPnP so theoretically there is no need to do any port forwarding.
