Kmassimo
Jul 30, 2020Aspirant
Using Netgear and Orbi modems
I have NETGEAR - 32 x 8 DOCSIS 3.1 Cable Modem less than six months old. I now need a new router and I'm looking at the Orbi whole home mesh with the modem built in. Can I use both? Is there any bene...
Jul 30, 2020Guru - Experienced User
Which model NG modem do you have?
No, it's one cable modem per one coax line that comes from the ISP. You can't use both at the same time.
Kmassimo
Jul 31, 2020Aspirant
CM1000
Is there another router I should consider? One that would work with my current modem?
