ABemis
May 14, 2020Follower
Using Nighthawk extender with a Netgear mesh system
Can a Nighthawk X4 AC2200 model 7300 extender be used with an Orbi Tri-band mesh system RBK23 to provide an extra extender?
1 Reply
If you've got one, you can try it. The most recent firmware 1.0.2.144 shows a fix for working with orbi products.
If you don't have one, I wouldn't buy one. I'd look into an actual orbi satellite. It'll have better performance, stability, and maintain the single ssid function properly.
