BakaNeko59
Aug 27, 2019Follower
Using old Asus router to extend Orbi to basement
I have been using an Orbi router and satellite to provide wifi throughout the main floor of my house and it has been working great. However we just got done finishing out our basement and the current...
Aug 27, 2019Guru - Experienced User
YEs you could use the ASUS as a wired AP. Keep the channels far appart from the Orbi channels. I would try a different SSID at first to see how it works. Then try using the same SSID name.
Yes you can use the wired ethernet connection for RBS. Direct connection is recommended. Use of switch can be used, however managed or green ethernet feature supporting switches are known to cause problems inbetween the RBR and RBS.
