NorbM
Mar 08, 2017Aspirant
Using Orbi as a Bluetooth extender
It would be great to be able to use the Orbi built in Bluetooth radios to extend bluetooth reach throughout a home.
NorbM
Mar 09, 2017Aspirant
The Orbi has a Bluetooth Radio. If you can use those radios as Bluetooth extenders it would help with home automation devices (they just need to be close to an orbi pod.
- rhester72Mar 09, 2017Virtuoso
If you're referring to the SmallNetBuilder teardown, they were wrong. Yes, it's on the SoC, but not enabled, and you certainly can't use it with a phone app (or anything else) for setup...that's done entirely via web UI.
Even if you could somehow enable the radio, you *still* can't extend with it.
Rodney
