NorbM
Mar 08, 2017Aspirant
Using Orbi as a Bluetooth extender
It would be great to be able to use the Orbi built in Bluetooth radios to extend bluetooth reach throughout a home.
NorbM
Mar 09, 2017Aspirant
The Orbi has a Bluetooth Radio. If you can use those radios as Bluetooth extenders it would help with home automation devices (they just need to be close to an orbi pod.
rhester72
Mar 09, 2017Virtuoso
If you're referring to the SmallNetBuilder teardown, they were wrong. Yes, it's on the SoC, but not enabled, and you certainly can't use it with a phone app (or anything else) for setup...that's done entirely via web UI.
Even if you could somehow enable the radio, you *still* can't extend with it.
Rodney
