bc22889
Dec 11, 2017Aspirant
Using Orbi as an Extender.
Hello! I purchased the Orbi not too long ago in hopes of using it to extend my connection. I live in an apartment complex and everyone in the complex has Wireless Modems and routers, so needless ...
- Dec 11, 2017
Orbi does not extend another AP's wireless signal like a traditional extender.
You can connect the Orbi router to your existing modem with a wire and place Orbi in a more central point in your apartment. Or, you can place the Orbi router near your existing modem and purchase an Orbi satellite and place the satellite closer to your bedroom.
In either case, you should turn off the WiFi on your existing modem. If your existing modem is a router, then you should also run Orbi in access point mode, or bridge your existing modem so it does no routing.
I don't think Orbi is a great choice for an apartment complex. Orbi uses a lot of channels in 5 GHz and broadcasts a powerful signal, so you will probably be stomping on your neighbors.
st_shaw
Dec 11, 2017Master
No problem. Orbi should work well in your house.
You cannot completely turn off 2.4 on the latest firmware. You can only reduce power to 25%. If you want to connect only to 5 GHz, you would need to implement the procedure posted by @khad to create unique SSIDs for 2.4 and 5 GHz.
bc22889
Dec 12, 2017Aspirant
Yes, I noticed that. My Modem used to have the ability to Adjust 2.4 and 5 independently, but now its a no Go as well. As of right now, It seems all of my devices are connected to the 5Ghz automatically. I also bought a longer Cat5e cable and Ran the Orbi to my Hallway by moving my couch and watercooler around and securing it to my wall so my cats wont trip over it while running about. Its working ok now. Getting about 4 out of 5 bars to my bedroom now.
It still irks me because the entire Apartment is 980Sqft, and my orbi is in the dead center wit my bedroom being exactly 9 feet away from its current location, and its fluctuating between 3 and 4 bars, never getting a full 5. My modem was having the same issue too, So i think its just because of way too much interfearence. It will probally work much better once I move.
I did also purchase 1 Satellite, so I am waiting for it to get here and going to install that in my bedroom.
