Soelau
Mar 02, 2023Aspirant
Using Orbi nbr750 as fail over option for UDM WAN connection
I’m trying to figure out how I can set up the NBR750 as a fail over Internet connection on the UDM router. So it means I will not be using the router of the NBR750. I’m having trouble finding a way to...
Soelau
Sorry ubiquity dream machine se
CrimpOn
Mar 02, 2023Guru - Experienced User
Ubiquity Dream Machine appears to be a similar concept:
- allow multiple internet connections
- sense when one no longer provides service and "fail over" to the other one.
In addition, Ubiquity also provides a "load balancing" feature where both internet connections are used at the same time.
My sense is that these products do not "fit". The Orbi expects to be a router with two ISP connections. The Ubiquity Dream Machine expects to be a router with two ISP connections.
- If the Ubiquity is to be the primary WiFi system, then the way forward is to get an LTE modem of some sort for the failover path.
- If the Orbi is to be the primary WiFi system, then either remove the Ubiquity (and use the ISP modem) or put the Ubiquity into passthrough mode.
Sorry not to be more help.
- SoelauMar 02, 2023Aspirantappreciate your reply never the less. I am not gonna be using Wi-Fi at all on any of them. What about bridge or ap mode are these not relevant?
- CrimpOnMar 02, 2023Guru - Experienced User
Soelau wrote:
appreciate your reply never the less. I am not gonna be using Wi-Fi at all on any of them.It seems a bit odd to purchase two WiFi routers and not use WiFi on either of them.... But... whatever.
The NBR750 does not have to be in bridge mode to serve as a failover for the Ubiquiti.
Unless.... (of course), there is a need to support applications that require a public IP address.
(port forwarding, VPN into the LAN, certain internet gaming.
Since Ubiquiti seems to be the primary system, I would tend to defer to Ubiquiti support for the best way to provide failover.
- SoelauMar 02, 2023AspirantI bought the orbi as part of a low-cost 5G connection. Where are the orbi what is included. But maybe I should consider using this product instead of the dream machine if you guys think it’s a great ruler and can handle fail over scenarios. But my scenario is I need to have external static. IP address is on both my connections and I wanted to let the dream machine to the routing. I hope you understand why I don’t actually need the Wi-Fi.
