SethOx
Nov 02, 2020Guide
Using Orbi RBK12 with bundled modem/router?
Hi, I’m in the UK and my internet provider is Post Office Broadband. They provided a bundled modem/router, and there doesn’t seem to be any obvious way to put it into bridge mode (I.e. modem only). Lo...
- Nov 03, 2020
No, as the RBR has a firewall running when in router mode so you can use the DMZ for the RBR running in router mode.
Nov 04, 2020Guru - Experienced User
To find the IP address give to the RBR from the modems router, look at the modems connected clients page for this IP address.
You might do a factory reset on the RBR and walk thru the setup wizard. This should change the IP address on the RBR to something else that doesn't conflict with what the modems is using. The RBR should detect this and change to maybe a 10.0.0.1 address schema...
