jupitious
Nov 25, 2020Follower
Using Orbi RBR 50 Router without Modem
For the last few years I've been using the RBR50, exclusively, as both my router and modem. I have Verizon FiOs. In addition to the router, I have 2 satellites (RBS50 & RBS20). Everything I've re...
Nov 25, 2020Guru - Experienced User
No. Your getting to near spec speeds. WIred speeds and limitaions of CPUs and connection rates, you only see around 900Mpbs or just over. You not see exatly 1000Mpbs on the wire. Wireless maxes out at around 400-500Mbps on 5ghz depending on the wifi devices design and support.
Your fine.
