Hawk1430
Oct 15, 2022Follower
Using Orbi with current WiFi Network
I currently have. Motorola Cable Modem/Router for my Xfinity internet/voice service and I want to use an Orbi router/satellite to extend the range. Can that be done and if so how? Also, are there only...
Oct 16, 2022Guru - Experienced User
What xfinity box do you have?
You could us the xfinity box as a modem only device and connect the orbi to it. That'd let you use the orbi system.
Or you could even leave the xfinity in router mode and connect the orbi to it in access point mode.
It just depends on what you're trying to accomplish.
