77PALE77
Jul 11, 2019Apprentice
Using RBR20 ORBI as a satellite
Hi everyone, I have an Orbi RBR20 router connected with a Orbi RBS20 satellite. I wonder if I can use another RBR20 router as a satellite instead of another RBS20. Thanks a lot Pale77
- Jul 11, 2019
Sorry, No. Even though they often appear to be the exact same hardware, the firmware for Orbi router and satellite are different. A router can only be a "router", never a satellite.
What you CAN do is attach the router to your Orbi as an "Access Point" (AP), which means:
- It performs no router functions
- It is not part of the Orbi "system". i.e. it doesn't coordinate anything with the main Orbi network
- It is just like buying an Access Point from anybody and hanging it off the Orbi (i.e. probably a lot more expensive than an Access Point from almost any vendor, including Netgear)
- If a device connects to this AP, when it moves around the house there is no "hand off" coordination between this AP and the Orbi (but then maybe most devices don't move around much).
All-in-all, most people opt not to do this
77PALE77
Got it,
thanks a lot for your quick and precise answer!
Pale 77
