JohnBorzy
Aug 27, 2017Follower
Using RBW30 (doesn't show up on phone wifi settings)
I just setup a Orbi Satelite RBW30, everything is on and seems to be working but If I understand correctly from using extenders in the past, I should see the satelite in my wifi setting on my iphone to be able to choose it but it is never there. So I know I understand correctly, with the extender you should be able to connect to either the RBW30 or RBW50 using their info, correct? Please help. Thank you!
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello JohnBorzy
With orbi there is just one network and you do not have to switch between the router and the satellite it will automatically do that for you.
DarrenM
