pshoule
Jul 22, 2018Tutor
Using Router Configured as Access Point Cannot see Satellites in web browser application
I am new here but I did search the forum to try and find and answer to this question:
IThe routers and satellites are all running firmware 2.1.4.16. When the router is configured as an access ...
Jul 22, 2018Guru - Experienced User
You can connect a wired PC to the satllites and log in there and update FW there...
Are the satellites wired or wireless connected to the router?
- pshouleJul 22, 2018TutorAs I have mentionned the backhaul is hardwired meaning that all satellites and the router are plugged in the network via a switch... a netgear switch :-(
So yes I understand, actually I knew, I could update the satellites via a direct connection but my question is: why can't ther Web app see the satellites?
Thanks
Simon- FURRYe38Jul 22, 2018Guru - Experienced User
What is the model of the NG switch?
Does the Routers web page see the satellites if you directly connect them to the router, by passing the switch?
- pshouleJul 23, 2018Tutor
Thanks FURRYe38,
the switches are Netgear ProSafe JGS516PE. I must say I haven't tried that yet but I sure will tonight and let you know what happenned.
Thanks
Simon
