boombox
Jan 17, 2020Aspirant
Using satellites as a managed switch?
Hi there, I was wondering if i can use the Orbi RBS50 satellites as a sort of managed switch as well when they are in mesh? My idea was to have one LAN port output IPTV and the other LAN port...
- Jan 18, 2020
RBS only work as a wireless repeater and the LAN ports are unmanaged only. You can connect Orbi to other switches, even managed however all IGMP protocols on a managed switch needs to be disabled.
boombox wrote:Hi there,
My idea was to have one LAN port output IPTV and the other LAN port internet (both using a different VLAN).
Is this possible? Or can only the router unit do this?
Thank you.
boombox
Jan 18, 2020Aspirant
Thanks!
Actually i'm not aware because i didn't buy them yet. I just wanted to know before buying, so i know if it works in my preferable setup.
CrimpOn
Jan 18, 2020Guru - Experienced User
Great idea to check things out before spending a lot of time and money!
Since my answer was basically, "I know nothing", you might want to check out some of the posts that include IPTV. I did a simple Google search "orbi and iptv" and got hits about ATT's IPTV, German IPTV, etc. I only glanced at them, but some seem to mention connecting things to the satellite. I also favor a really direct post, "Orbi and IPTV from ???".
