nicholasbc
Mar 24, 2020Aspirant
Using satellites from another identical model of Orbi RBK14--AC1200
If I have 2 identical Orbi systems, each with a router, and 3 satellites, can I use all the 6 satellites with one of the 2 routers? thanks Nicholas
CrimpOn
Mar 25, 2020Guru - Experienced User
Several users have reported having up to six satellites on a single Orbi router. So, YES.
There appears to be a "trick" to doing this in the sense that the web page for adding a satellite has places for only three.
What people appear to do is temporarily unplug one of the satellites, so it becomes "disconnected."
That creates room for one more.
After it is added, do the same thing to add another, and another.
When all have been added, power them up again and "Voila", you now have six!
(I have not done this myself, having only a single satellite.)
nicholasbc
Mar 25, 2020Aspirant
Thanks so much-I'll give that a try, and report back.
my first steps were to try to get the "shirt tail" relations (satellites) talking to the other router, but the length of time needed for the process of electronic registration is like watching paint dry! It's easy to miss a step when my patience is so challenged.--Nicholas
- nicholasbcMar 29, 2020Aspirant
Further efforts to use extra satellites from the 2nd duplicate system failed for me.
The network is working satisfactorily, BUT i now have a non functional "ghost" satellite on my network map.
Has anyone experienced this, and how was the "ghost" exorcised?--Nicholas
- FURRYe38Mar 29, 2020Guru - Experienced User
Make sure the RBS FW is the same as what your using on your RBR. Turn OFF all other RBSs and attempt to add the RBS to the RBR while in the same room as the RBR.
nicholasbc wrote:Further efforts to use extra satellites from the 2nd duplicate system failed for me.
Thanks for your reply.
I presume the RBR is the router, and the RBS is the satellite, but the FW is an unknown accronym.
When I started doing the setup, I initially tried seting up the router with one of the satellites from the second system, but never got the blue light sync signal. I tried using a pin to press all the resets, and then the sync buttons, but with no success.
I might be able to try and access the router setup, and change some values in its brain, but that might just brick the unit as well.--Nicholas
