JasonTeh
May 16, 2020Aspirant
Using smaller amps adapter for Orbi Satellite RBS50
Hi community of Orbi users, Appreciate your assistance/advice. • I recently bought a pre-owner Orbi Satellite RBS-50, but the seller provided me with a non Orbi adapter with the output rating of...
JasonTeh
I found this Netgear page on using wrong adapter...
https://kb.netgear.com/000028995/Information-about-the-power-adapters-on-NETGEAR-products
It states:
What if I use the wrong power adapter?
Your product could be unsafe to operate.
You could cause serious damage to the product.
Your product could mysteriously reboot, drop connections, or have range and performance problems, etc.
Using your product might violate the law.
Umh....
It states:
Umh....
CrimpOn
May 16, 2020Guru - Experienced User
All of that is true. Terrible things "might" happen. Good luck finding an original Netgear brand power supply. I found exactly one (used) on eBay. Everything else was third party equivalent. 3.5amp at 12v with the correct size plug is what is important.
