geoffdm
Sep 20, 2018Aspirant
Using the Mac Remote Desktop software - Mac to Mac remote management
Hiya,
I have recently purchased the Orbi RBK53 Router with two satalites.
When i connect to the Orbi network i cannot remotely manage my iMac using the Mac software Remote Desktop, when i swi...
Sep 20, 2018Guru - Experienced User
What FW is currently loaded?
How are the Macs connected to the orbi system? Wired or Wireless?
Where are the Macs connected, to the base router or the satellite, one at the base router and the other at the satellite?
If there both on the same connection point, there shouldn't be any configurations needed.
geoffdm
V2.1.4.16
Truespeed -no idea of modela s it is whitelabel
Wireless
Where are the Macs connected, to the base router or the satellite, one at the base router and the other at the satellite? Both the main orbi router at the moment
If there both on the same connection point, there shouldn't be any configurations needed. Ok, strange as its not working. Thanks though for comments!
My Setup (Cable 900Mb/50Mb)CM1000r>XR450> > EX7700 (Wireless Extender)
Additional NG HW: Orbi CBK40(Gateway Mode), R7800, EX7500/EX7700 and WNHDE111
- Blanca_OSep 26, 2018NETGEAR Employee Retired
Hi geoffdm,
Welcome to NETGEAR Community!
Have you tried resetting the router and the satellites?
Blanca
Community Team
