Shaun1001
Jul 28, 2021Aspirant
Using to different packs of Orbi together
Hi, I am hoping for some advice, please. I bought 2 packs of 3 Orbi RBK53S. Having received them I have found that the packs contain 1 router and 2 satellite units, although it says this on t...
- Jul 28, 2021
Yes the RBS from the 2nd RBK kit will work on the 1st kit.
Jul 28, 2021Guru - Experienced User
if you use google, theres an unofficial way of converting an rbr50 to an rbs50.
There's a chance you brick your device but if you don't have a use for it otherwise, might be worth a shot.
Or you could use it as backup.
Or sell it and use the $ for another satellite.
Just some thoughts :)
- Shaun1001Jul 29, 2021Aspirant
Thank you, I will look into this :)
