timkym1
Dec 09, 2019Follower
Using Wyze Smart Plug with Orbi
I have purchased a set of Wyze smart plugs for my home and recently installed an Orbi system. I am trying to figure out how to connect with 2.4ghz, the setup does not work because of the 5ghz. Any help???
timkym1 wrote:I have purchased a set of Wyze smart plugs for my home and recently installed an Orbi system. I am trying to figure out how to connect with 2.4ghz, the setup does not work because of the 5ghz. Any help???
At what step in the setup did things go bad? I am assuming that you followed the "Simple Setup" directions on this page:
If your having problems with the setup process installing these devices, please use this method to help get them installed:
