waresull
Feb 28, 2017Follower
Uverse Pace 5268AC Residential gateway and uverse wireless TV receivers and orbi
Will the solution I copied and pasted below work for the Uverse Pace 5268 gateway? I have a Uverse Pace 5268 residential gateway that ATT connected a WAP to in the LAN 1 spot. There are 2 wireless ...
Kenswift
Feb 28, 2017Aspirant
I'm in the same boat and can't get it to work. Seems that solution worked for the previous gateway but not ours. It might be able to be done so I hope someone has the answer.
