tolive
Jul 12, 2017Guide
V1.12.0.18 still having disconnect issues
Unfortunately, (for me) the latest firmware doesn't resolve the wi-fi disconnection issue. I updated both router(RBR50) and satellite(RBS50) to V1.12.0.18 from V1.11.0.20, factory reset both, starte...
DarrenM
Jul 12, 2017Sr. NETGEAR Moderator
Hello tolive
Did you try and tell your devices to forget the network and then connect again some old settings could be causing issues.
DarrenM
JMU1998
Jul 12, 2017Luminary
With the new Firmware my devices are getting Stockton the 2,4GHz can we please have the option to atleast reduce the 2.4GHz radio strength if not disable like before?
