tolive
Jul 12, 2017Guide
V1.12.0.18 still having disconnect issues
Unfortunately, (for me) the latest firmware doesn't resolve the wi-fi disconnection issue. I updated both router(RBR50) and satellite(RBS50) to V1.12.0.18 from V1.11.0.20, factory reset both, starte...
drmonkey
Jul 13, 2017Initiate
Yep, I'm actually having worse disconnects now. This is downright ridiculous. And apparently we can't downgrade the firmware to something that actually works because we're forced to auto-update. I really wish I were within my return period as I would get rid of this and go back to my old router.
DarrenM, could I also get in on working with the support team? I've done a factory reset and it did nothing for my disconnects.
esiebert7625
Jul 14, 2017Star
fyi if you manually downgrade it won't auto upgrade back to a higher version, mine just has the message saying the update is available
- chris5000Jul 25, 2017Tutor
Do you know where I can get the older firmware from. I can not even you my orbi system anymore.
- DarrenMJul 27, 2017Sr. NETGEAR Moderator
Hello Chris
Here is the link to all firmware.
http://www.netgear.com/support/product/RBK50.aspx#download
DarrenM
- madbrainAug 24, 2017Luminary
esiebert7625 wrote:fyi if you manually downgrade it won't auto upgrade back to a higher version, mine just has the message saying the update is available
That is simply not correct. After a few days to a week, it will auto-upgrade to the latest again.
- chris5000Aug 24, 2017TutorThank you for your response. May I ask what version of firmware are you using.
- cyberprashantAug 24, 2017Luminary
A few of us have sucessfully blocked it. Not sure what the magic was (it took several tries I know) --> I have 2 orbi systems both downgraded now over 3 weeks ago firmly stuck on 1.11.0.20 (confirmed). It does show every time that an upgrade is available (resist clicking it). . The key here was there is a router ahead of the orbi (orbi WAN , connected to lan port of old r7000) - that router ahead has downloads.netgear.com blocked. That block has to be in place before the downgrade.
Agree - way too complicated and frustrating tho - not sure why netgear does not have a way to disable this.
That is my exact setup - R7000 as router, Orbi WAN connected to R7000 LAN port.
Blocking downloads.netgear.com in the R7000 did not work for me. I had no less than 4 automatic upgrades to the latest in this configuration. All my attempts at preventing upgrade failed.
Last time I had an auto upgrade, and I did a manual firmware rollback, my Orbi router got bricked. I got a replacement from Netgear monday. Right now, all running the latest firmware since then without satellite dropoff issue yet, knocking on wood ...
ah sorry to hear it keeps upgrading. But if its stable knock on wood and hopefully they say an update is coming soon. BTW: when I browse to downloads.netgear.com on a PC connected to the orbi I get this: http: // downloads.netgear.com/ --> Invalid URL
Invalid URL
The requested URL "/", is invalid.
Reference #9.7655e68.1503637424.44fe4e2
THis tells me the block is in place. See if you are getting that. The stupid thing is super fast at upgrading post-downgrade so post-downgrade (for whcih ideally u have the files for 1.11.0.20 saved on your PC, disconnect orbi from the internet (wan port) and then issue the telnet commands quickly and only after you are sure you have successfully downgraded and issued the correct telnet commands with the committ statement reconnect WAN port.
Even still i think it took several tries. This is more than anyone really needs to be doing netgear so pls get the update out SOON!
Invalid URL
I removed my block in the R7000 for now. And yes I have the 1.11.0.20 firmware saved up on a local PC.
I think I may really have been running into the problem with space in the password.
I setup the Orbi router with no space in the passphrase (only characters, actually). Made it a hidden SSID (not broadcasting).
Used the SSID / password that all my devices are setup for as "guest network". Everything working fine for 3 days so far, no satellite drops. I think this is longer than I ever had it work before with 1.12.0.18 firmware.
