tolive
Jul 12, 2017Guide
V1.12.0.18 still having disconnect issues
Unfortunately, (for me) the latest firmware doesn't resolve the wi-fi disconnection issue. I updated both router(RBR50) and satellite(RBS50) to V1.12.0.18 from V1.11.0.20, factory reset both, starte...
mboyce
Sep 05, 2017Aspirant
I am having the same issues. New Orbi RBR50 and satellite installed Sunday 9/3 and had disconnects within first hour. Have not timed the intervals, but happens multiple times per day on android phones, ipad pro, 3 PCs, an Amazon Echo all lose connections and then a short time later reconnects. Annoying as hell for something this expensive.
- cyberprashantSep 05, 2017Luminary
mboyce wrote:
I am having the same issues. New Orbi RBR50 and satellite installed Sunday 9/3 and had disconnects within first hour. Have not timed the intervals, but happens multiple times per day on android phones, ipad pro, 3 PCs, an Amazon Echo all lose connections and then a short time later reconnects. Annoying as hell for something this expensive.your only solution is to downgrade for now (until such time orbi releases a new firmware) to 1.11.0.20xx firmware - see the post above and also the main 1.12.0.18 discussion thread on how to downgrade. I had the same problems with Amazon echo dropping and now complete stability - downgrade sticking now > 1 month. Total orbi time probably 1 year in that time my only problems were when 1.12.0.18 got released. The tricky part is preventing the auto-update. If you have a router to plug the orbi into and in that router can block downloads.netgear.com first, that's how I did mine. I guess a lot of ppl are having trouble getting the downgrade to stick
- Mikey94025Sep 07, 2017Hero
If you decide to downgrade, here are the telnet instructions to make it stick: https://community.netgear.com/ejquo23388/board/message?board.id=Orbi&message.id=10304#M10304
- Peace_105Sep 07, 2017Aspirant
Thanks for input. I have stopped use the Orbi system (just sits on shelf and look pretty). I'll get a new optic fiber to the house soon instead of using 4G or DSL and will give it a new try after that...
