wziemer
Oct 29, 2016Star
V1.3.0.12 - Outstanding Issues
Model: Netgear Orbi RBK50 (Orbi Base + Satallite) Firmware: V1.3.0.12 OS: Not relevelnt, but Wndows 10 Pro x64 anyway Browsers: Any, Primary Browser is Chrome though. I have seen several peopl...
peteytesting
Nov 18, 2016Hero
general question regarding this passphrase thing
are ppl using an ssid that they have used before on other routers or are you using a new and unused ssid for the orbi system ?
Hydro130
Nov 19, 2016Luminary
peteytesting wrote:general question regarding this passphrase thing
I came from an Asus 5300, and I kept that primary SSID/password when I switched to Orbi. I have a couple of iPhones (SE and 6S) and an older Macbook Air, plus a variety of HA tools (Honeywell RedLink, SmartThings hub, Hue hub, Harmony hub, Google Home x5) - all have worked very smoothly on Orbi and the "old" SSID.
The only consistent glitch I have with the Orbi is whenever I need to reboot it (firmware update, etc)... It always takes a few reboot cycles to finally "catch" and fully connect to the interwebs. I've had this issue with both v12 and v26 of the firmware. But if that's the worst thing I have to live with for this router, I'll very happily do it!! :)
Cheers, Chris
