mastervisa30
Jan 17, 2018Luminary
V2.1.2.18 new firmware is out
I get this now,new firmware upgrade is available V2.1.2.18 when i checked for uodates.
AF1E
Jan 17, 2018Guide
After 6 days of uptime using 2.1.2.10 beta, I upgraded to 2.1.2.18 this morning. The random rebooting has returned. Will continue to watch today before I go back the beta which was stable for me.
- budyJan 17, 2018Luminary
I just installed 2.1.2.18 on my RBK40 satellite and router and now the former working ethernet backhaul, doesn't seem to work anymore. No matter what, I am doing, the attached deviced page shows the satllite as connected via 5G. If I reboot the satellite, it changes to wired backhaul, but then the other devices show up as being all connected wired to the router.
After some time, the satellite will turn its LED to static violet and needs to be either synched or rebootet.
- ALNJ2017Jan 17, 2018Star
Orbi rouyer is crashed after .18 update.
power led blinks green
Ring Led is soliid white.
No WiFi SSID is broadcast.
- JMU1998Jan 17, 2018Luminary
Took v2.1.2.18 a few hrs ago did factory reset, nvram clear now sattalite does not show as connected sattalite but as attached as a device to the main Orbi unit so basically this Firmware made it worse for me! Yes I rebooted both several times as well anyone else seeing this?
- budyJan 20, 2018Luminary
budy wrote:I just installed 2.1.2.18 on my RBK40 satellite and router and now the former working ethernet backhaul, doesn't seem to work anymore. No matter what, I am doing, the attached deviced page shows the satllite as connected via 5G. If I reboot the satellite, it changes to wired backhaul, but then the other devices show up as being all connected wired to the router.
This is just fine, if the sat is connected via ethernet "backhaul". This has been an ongoing issue since 2.x. It seems that the script which parses the internal network bridges isn't yet able to pull this all correctly together. However, it's just a cosmetic issue and does not impede the actual function of the router <-> sat connection.
- MikedeisslerJan 20, 2018Star
Budy, are you saying that devices that are connected to the satellite with a wired connection are reporting they are connected 5G to the router or that the devices that are wired to the satellite are saying they are a wired connection to the router? I would expect that with a hard wired backhaul any wired device attached to the network would say it's connected to the router since the satellite is just a switch in that topology. Are you still having problems with the satellites not connecting to the wired backhaul?
