mastervisa30
Jan 17, 2018Luminary
V2.1.2.18 new firmware is out
I get this now,new firmware upgrade is available V2.1.2.18 when i checked for uodates.
budy
I just installed 2.1.2.18 on my RBK40 satellite and router and now the former working ethernet backhaul, doesn't seem to work anymore. No matter what, I am doing, the attached deviced page shows the satllite as connected via 5G. If I reboot the satellite, it changes to wired backhaul, but then the other devices show up as being all connected wired to the router.
After some time, the satellite will turn its LED to static violet and needs to be either synched or rebootet.
ALNJ2017
Jan 17, 2018Star
Orbi rouyer is crashed after .18 update.
power led blinks green
Ring Led is soliid white.
No WiFi SSID is broadcast.
- JMU1998Jan 17, 2018Luminary
Took v2.1.2.18 a few hrs ago did factory reset, nvram clear now sattalite does not show as connected sattalite but as attached as a device to the main Orbi unit so basically this Firmware made it worse for me! Yes I rebooted both several times as well anyone else seeing this?
- OrbiUser456Jan 20, 2018Tutor
This system is a total piece of cr$p. Nothing but problems, reboots. Can you guys write any firmware? There have been multiple releases, all with problems. I wish I could get my money back and buy something else!
