packetwerks
Apr 02, 2018Star
V2.1.3.4 Bridging
Starting a new thread specific to my issue. So I woke up this morning to V2.1.3.4 being installed. Not only was my wireless network down but so was my wired network. Started troublshooting and notice...
Apr 02, 2018Guru - Experienced User
OK, just asking. Was a full factory reset performed on both router and Satellites and setup from scratch yet?
Any network switches between the router and satellite?
What is the mfr and model# of the ISP modem your using?
When trying to use Daisy Chain, I presume you physically have the Satellites piggy backing of each other and not wired for back haul ?
I would also try this. Test with the router alone. Turn off all Satellites. Then graduate by adding one Satellite via wireless. Test for issues. Then add another.
packetwerks
Apr 02, 2018Star
Yeah I factory reset the router via the web interface first. Then reset each satellite via the pinhole. Physically resynced each.
Satellite----cat5----Switch----Orbi Router----Wireless Clients
Satellite----/ |
Switch-----VMware Server---Firewall----internet
Other hardwired stuff (e.g. AppleTV, etc.)Notes: Switches are D-Link DSG-1100-16/24 with default, unmanaged configs. ISP Cat5 goes right into firewall. No modem.
Firewall is a VMware-based Sophos XG appliance. It does DHCP and has not been changed in a long time. Not doing any fancy IPS or any other strange things to internal traffic. It's basically a "dumb" router at this point.
Not sure what you mean by "physically have the Satellites piggy backing of each other" I have both satellites connected to the same ethernet switch so that they can setup the bridge between them -- it was working in the previous firmware. Do I need to directly connect (e.g. via a coupler/barrel connector) each Orbi to make ethernet backhaul work?
Thanks!
Edit: tiny edit to better reflect network topo.
- FURRYe38Apr 02, 2018Guru - Experienced User
You might try changing the configuration to daisy chain the 2nd Satellite off the first one, instead of both connected to the same switch and see if this changes anything. Don't enable Daisy Chain on the router. Just see if adding the 2nd Sat to the back of the 1st Sat does anything different. I would also just as a quick test, take the switch out of the mix and directly connect both to the Orbi router. See if anything seen is different.
I have this similar network configuration. There is 2 unmanaged switched between my 1 satellite and the router. I don't have a 2nd Sat at this time so I can't test this with you.
Is this your switches?
http://us.dlink.com/products/business-solutions/dgs-1100-16/
If so, these are managed switches...
- packetwerksApr 02, 2018Star
I'll give that a try -- although this is one of those things where (this time!) I didn't change anything. There was a change within Orbi that made bridging different. I just am not sure what changed.
And yes, those are managed switches -- but like I said the configs are both factory default with no changes.
Thanks for the help!
Something to narrow down, go direct with the Satellites to test with the router.
Even though using default settings, there maybe differences between these managed switches vs non manages switches that could be causing problems with newer FW. Seems to be a change in FW though.
Is the Orbi is running in router mode or AP mode?
