packetwerks
Apr 02, 2018Star
V2.1.3.4 Bridging
 Starting a new thread specific to my issue. So I woke up this morning to V2.1.3.4 being installed. Not only was my wireless network down but so was my wired network. Started troublshooting and notice...
Apr 03, 2018Guru - Experienced User
You might try changing the configuration to daisy chain the 2nd Satellite off the first one, instead of both connected to the same switch and see if this changes anything. Don't enable Daisy Chain on the router. Just see if adding the 2nd Sat to the back of the 1st Sat does anything different. I would also just as a quick test, take the switch out of the mix and directly connect both to the Orbi router. See if anything seen is different.
I have this similar network configuration. There is 2 unmanaged switched between my 1 satellite and the router. I don't have a 2nd Sat at this time so I can't test this with you.
Is this your switches?
http://us.dlink.com/products/business-solutions/dgs-1100-16/
If so, these are managed switches...
packetwerks
Apr 03, 2018Star
I'll give that a try -- although this is one of those things where (this time!) I didn't change anything. There was a change within Orbi that made bridging different. I just am not sure what changed.
And yes, those are managed switches -- but like I said the configs are both factory default with no changes.
Thanks for the help!
- FURRYe38Apr 03, 2018Guru - Experienced UserSomething to narrow down, go direct with the Satellites to test with the router. Even though using default settings, there maybe differences between these managed switches vs non manages switches that could be causing problems with newer FW. Seems to be a change in FW though. Is the Orbi is running in router mode or AP mode? - packetwerksApr 03, 2018StarJust connected one satellite directly to a 2nd LAN port on the router. By the time I got to the satellite it had a blue ring. Looked at router web UI and see that it still says it's backhauled to the router via 5G. Didn't reboot anything but ran a speed test via the now hard-wired sattelite and saw 700+mbits - Which means that the web UI must be out of date because I wouldn't see that speed from that satellite if it was backhaul'd via 5G. Going to do the same with the other wired satellite. So this seems to indicate that something changed with the bridging where the satellites must be directly connected and not via the switch (since it will cause a storm). I do notice that spanning tree protocol is enabled on the router bridge (brctl show) but not on the satellite bridge. I'm not sure if that has something to do with it, but the fact that the firmware update introduced a loop into my network sure makes me think that's a good clue. Hope this helps. - FURRYe38Apr 03, 2018Guru - Experienced UserNeed to give time to the router or clear broswer caches and refresh for the back haul to appear correctly. I rebooted the router then cleared browser cache, exited the browser then reopened and logged into the routers web page. Add the 2nd Satellite direct to the router then try daisy chain behind 1st Sat. I'm wondering if there is a problem with your switches...Do you have an actual non managed switches you can try? Would need to help rule this down to your managed switches or something in FW.
